My new accessories
Do you mean the 5-blade that Chris picked up? I'm interested in the greater thrust...
Exactly. Buy a set. These props are available just about everywhere, in FPV stores too, not only on Ali.
I bought the 5 blade props specifically to see if they would add more thrust to the NEO so that it could support the extra weight that the added bottom light (40g), the top mounting bracket (~16g), and the penlight (20g) added. With the stock 3 blade props the NEO kept making sudden drops in altitude, but with the 5 blade ones it flies smoothly with all the extra weight.
There´s also a 4 blade version from this prop. If the load isn´t so heavy. these have a little longer flight time. I use them, when the weather is a bit windy. The Neo flies more stable, than with 3 blades.
There are a few NEO 2 batteries on Aliexpress which are genuine and not very expensive if you can find a deal using coupons, etc. Takes awhile to arrive but I paid @ $60.
Reactions: jaja6009
Is that per battery cost? They are USD $39 on DJIs website here in Canada. Is that the price you have to pay after tariffs are added?
To me, it is shocking how much the cost of drones and drone accessories now cost in the US. In the past it has always been the opposite - prices in Canada have been higher for everything relative to the same thing in the US. I feel for all of my fellow US drone pilots and hope the situation will eventually get better.
I was looking at grabbing one more battery for my neo 2, but the price point isn’t doing it for me. If I buy a $65.00 battery and then pay $20. for shipping and then $9. sales tax at 94. that’s too much. There’s many sellers that are possibly cheaper but then it’s a gamble as to the seller for me. In light of everything that’s going on now I haven’t even opened the box just yet. I got it 6 days ago.
Yes, ~$60 OTD so that includes tax, tariffs, fees, everything. Again, I think you can get a discount if you find a good coupon or cashback somewhere. But yes MSRP $39, retail $58 is not super terrible but you can buy as many as you want without having to buy the kit and then sell the drone (which I am doing as well).
Yep, that's why I took the chance on the BF deal from Ali; my big risk is whether they were OEM or not and turns out, they are genuine DJI. I'm not sure if these prices are going up or down; they seem to be doing a lot of both.
And then I might try one of these: https://www.aliexpress.us/item/3256810411297136.html
On the accesory front I have some information.
For the Neo 2, there is a charger now available that offers a storage mode (50 - 60%)
Next, the downward light for the Neo can have problems with altitude.
I was flying indoors with no GPS with a forward facing and downward light installed.
This was a large bay with a 20 foot ceiling. The lights were on in this bay, but the lighting is not good.
The Neo would not be able to see the ground since the downward lights were not bright enough and would go into Attitude mode. The Neo suffered one crash, but no damage.
The downward system was the popular one pictured here.
This light works great in pitch darkness. But in my tests, there is an altitude limit for it. Attitude mode happened only when the drone was 15 feet and above in altitude AGL.
That seems reasonable for this light because as altitude increases the light disperses making it less effective to provide enough light for the VPS.
I have also noticed that as the light discharges with use it becomes less bright. I have had my NEO go into atti mode a couple of times because it is not bright enough for the VPS. Keeping the light charged up before use solves this problem.
Reactions: jaja6009
I needed a 65W fast charging deveice to charge Neo batteries, because I had only 33W. The dji original one costs 45€ in the store, I found this in the IKEA, paid 14€ for that. With this 100W cable, it charges all 3 Neo batteries parallel. Can be used to charge smartphones, tablets etc. obviously.
Today I did some testing of the LED landing light outside in heavy snowfall in cloudy overcast conditions with the ground covered in a thick layer of freshly fallen snow. I was testing to see if the LED light would prevent the original Neo from going into Atti mode and losing stability/control in an otherwise difficult environment for the VPS to maintain stability. I set the Neo to Follow me (using my iPhone as control) and set it to far and flat. The Neo followed perfectly without any problem.
I then set the Neo to Direction Track and had it track me from the front again, set to far and flat and again the Neo tracked me without any problems. Usually Direction Track is much less stable than Follow but the Neo did a great job.
My next tests will be Direction track from the side which I have never had any luck with before over an open area fully covered in snow like an ice covered lake.
Overall, I was surprised and quite pleased with how well the LED landing light worked to mitigate some of the problems I have with the VPS system over snow. I made sure I covered the USB-C charging port with electrical tape just in case the Neo ended up in the snow.
This is another accessory that I have found helpful for all of my drones. Today I was out with my Neo and it was -9ºC. I set the Neo to Cruise Control and flew it along a bush trail covered in snow while I followed behind making small adjustments as needed. My hands did not get cold at all when using the transmitter mitt. I used my RC 2 controller rather than my N3 controller because the mitt is made for the all in one type controller. The only downside is that the plastic screen on the mitt fogged up a bit. It comes with anti-fog pads that fit into inside pockets but I will need to get some more silica gel packs and see if that helps with the fogging.
I have one my wife modified for me many many years ago that looks very similar. I used it for flying my Gliders in bitter cold. It has a sheepskin lining, only it is much bigger due to the size of the transmitter I used at the time. It worked extremely well for that purpose.
I also have a bigger version that I have for my Phantom 3 Standard.
Here's some new accessories that I picked up from AliExpress. The lens hood I bought because I was getting bad lens flaring
I have the lens hood it works good but if I tilt the camera up I can see the hood and I need to put my filter upside down to avoid damaging the gimbal. Other than that it saves your gimbal in collisions.
The lens hood, like many of my other Neo accessories is an accessory that is used for a specific purpose. I only use the lens hood when I am having the Neo track me via Active Track or Direction Track to reduce the sun flare coming through the trees which can be very distracting in the resulting video. It still happens with the hood but not as much.
I don't use the hood with any of my filters (K&F Concept clip-on) because the gimbal won't move, or when I shoot 360º panos because I do not want the gimbal in any of the frames.
Here’s a couple of cases I use for my neo.
I’ve seen that one.
I have several different types just to see what I thought and how well they would work for me. Everything has some sort of trade off with how you plan to fly. This hobby is very interesting and fun with so many options.
Lelembut13
