Freewell filters and...
NeoNeo
Received the Freewell kit containing one UV, CPL,and Mist filter plus two mounting rings. The mounting rings are a fraction of a gram metal with double sided adhesive on one side. The filters are magnetized allowing them to stick to the metal ring.
Optical quality is good. No need to remove when placing gimbal guard on. Minimal weight. They stay on during flight. But... if you crash they can pop off. Just an indoors test flight. Flying slow when I bumped into the legs of the coffee and dining room table trying to shoot through the gaps. More of a deflecting impact, but too low to regain control before impact with the floor. Both times the filter fell off. First time didn't even realize the UV filter came off until I saw it sitting on the floor. Filters need stronger or higher quality neodymium magnets. Even those may allow the filter to slide off on impact.
Thanks for sharing
Thanks for the review! 👍🏻
The mounting is a conundrum... The magnets can be no stronger than the adhesive holding the mounting ring on the camera barrel. Double-sided tape is pretty weak as adhesive is concerned.
Ideally theyd sell a kit with really strong magnets and corresponding small tube of adhesive to glue the mounting ring on the barrel.
But we know how that sort of thing goes when out in the wild public, off the engineer's workbench 🤣🤣
I ordered the Skyreet filters from Amazon (UV, ND8-ND64)They should be here after Christmas. They mount the same way as the Freewell ones.
I've been using the Sunnylife filters (the ones with a small plastic hook that get attached by "hugging" the gimbal's top part). No complaints at all, they work great.
I cancelled the Skyreet ones and ordered K&F concept ones. They include UV, PL, ND8, ND16, ND32, and ND64. They clip on securely with 2 little hooks. So far they have worked well.
Reactions: NeoNewbie
Mechanical clips probably hold better than the magnetic system if you ever crash.
Yah, that’s why I cancelled the Skyreet ones. The clip on ones aren’t as easy to put on or take off but they stay on securely.
Can you place the gimbal storage cover on with the filter mounted?
Eventually will lose or damage the filters and will need to replace. Magnetic mount is not ideal for the way I fly. Should change my ID to C&T(crash and trash)
Yes, you can put the gimbal storage cover on with the filter on.
Ordered the K&F filters. Freewell magnetic mounted are fine for gentle flying where crashing is highly unlikely. Manual mode and me = routine crashing. Indoors flying in N mode. Even crashes from 0.5M and lower has the filter popping off at times. Easy to find on the floor. Outdoors. Higher impact speeds and G forces on impact. Goodby.
Amazon, listed at the lowest price in the last 30 days. Forgot the % off. Less money to purchase the complete kit vs. couple individual K&F UA and/or CPL. ND8 might become the backup to a lost or damaged UV or CPL. The other 3 filters? More UAS stuff in the misc bin of parts.
Indoor Neo session today. Using the dining room table and chairs as slalom gates. Twice a deflecting hit sent Neo crashing. Relatively low speed and very low altitude crashes. But hard enough that the red impact detected warning box OSD appeared. Freewell would have fallen off. K&F filter stayed attach.
BlaineSets
