Using a fan
Do you use a fan when on and setting idle for updates ect?
I don't understand the question
Yeah, posted in a hurry. I meant there's no internal fan for cooling correct small size and all it needs airflow for cooling, right? Reason for my question is I'd rather change settings on the table instead of in the air, I did take it out for my first flight a little while ago and I can see where I will want to change the settings some. I've referred to some YT vids to give me a leg up on that on what to start with for desirable flight.
Yeah, posted in a hurry. I meant there's no internal fan for cooling, correct small size and all. Reason for my question is I'd rather change settings on the table instead of in the air, I did take it out for my first flight a little while ago and I can see where I will want to change the settings some.
Changing settings doesn't take that long. I have changed settings with it on a table and in the air.
What settings are you trying to change?
Ok, good to know. I was just worried about overheating, I seem to remember using a fan with my old mm that I sold. I'll just play with the settings on the fly (lol).
I always place a usb fan pointing my DJI drones (mini 3 pro, mini 4 pro, Avata 2) when I do updates as I never know how long it would take. They get hot and I just don’t want the risk of them shutting down due to excessive heat during an update.
ilkerix
