RTH smartphone
Adembar
Brazil
Website
www.youtube.com
I sent an email to DJI (n° 8626622) with the Suggestion: in a future update of DJI Fly to use a smartphone on NEO, there could be a configuration to “update RTH taking the smartphone as a reference”, because when using the smartphone and making a narrative, I usually move in several directions (within the limit of 50m:164ft) and with this, if NEO automatically triggers an RTH I will have to return to the place where I took off, but having this possibility of “following the smartphone” I will be safer.
Reactions: pincherfpv
Reactions: sarahb and Adembar
He knows that. What he's saying is that he suggested that DJI consider adding that capability.
If that's the case, it was not obvious, because when he said the following, it sure read to me like he thought a home point was being set with his phone and the neo was going to return there when he moves around:
...because when using the smartphone and making a narrative, I usually move in several directions (within the limit of 50m:164ft) and with this, if NEO automatically triggers an RTH I will have to return to the place where I took off, but having this possibility of “following the smartphone” I will be safer.
Well, you read it wrong or simply didn't interpret what was meant. Nonetheless, the OP knows to contact DJI with the suggestion.
SAFFIX
