- Joined
- Sep 9, 2024
- Messages
- 27
- Reaction score
- 28
- Age
- 46
Hello Friends, just a short PSA of how the NEO can be changed to FCC:
With this option you most probably can change the altitude from 120m to 500m for the neo also (not confirmed, will test this out ASAP, worked fine for mini 4k)
Please adhere to your local regulations and do not interfere others communication!
Happy flying
Options for Neo
- Currently, the easiest way to change to FCC is by having Goggles 3 with the HAM File on a SD Card
- The next (possible, but not yet working) way would be drone-tweaks.
Option 1)
Create a empty file (0B) with name "ham_cfg_support" in the root of your SD Card,
insert the SD Card in your goggles and keep it in there.
Not only will it change to FCC, it will also enable the 5.2 Ghz Band (if disabled in your region)
AND it can potentially unlock the speed (if limited in regions, it already does on avata 2)
Option 2)
Drone-Tweaks say they are working on it, due to the heavy app changes this can take some time.
If you know any other options, feel free to add them.Please adhere to your local regulations and do not interfere others communication!
Happy flying
