possible ways to enable FCC
djiuser12345
Active Member
Hello Friends, just a short PSA of how the NEO can be changed to FCC:
Options for Neo​
  1. Currently, the easiest way to change to FCC is by having Goggles 3 with the HAM File on a SD Card
  2. The next (possible, but not yet working) way would be drone-tweaks.
Option 1)​
Create a empty file (0B) with name "ham_cfg_support" in the root of your SD Card,​
insert the SD Card in your goggles and keep it in there.​
Not only will it change to FCC, it will also enable the 5.2 Ghz Band (if disabled in your region)​
AND it can potentially unlock the speed (if limited in regions, it already does on avata 2)​
Option 2)​
Drone-Tweaks say they are working on it, due to the heavy app changes this can take some time.​
With this option you most probably can change the altitude from 120m to 500m for the neo also (not confirmed, will test this out ASAP, worked fine for mini 4k)
If you know any other options, feel free to add them.
Please adhere to your local regulations and do not interfere others communication!
Happy flying
I think the range is determined by the battery capacity, not the signal strength, so I won't do fcc hack. By bigger drones, with longer flight time it makes sense, by the Neo not. But, thanks for sharing. I've seen a vid on YouTube, but wasn't interested.
FCC is not only for distance,
its probably the only way I can get around my house in the woods without connection interrupts.
This is ~50m with concrete/steel in the way
In other words: CE is a real challenge for manufacturers
Reactions: Christian
Actually agree. Maybe because of the penetration. I've hacked my Spark, but that had a real weak signal. I hate, that we europeans get weaker models, but I think this time I won't do it.
Interesting. Thanks for sharing
For me, signal strength is about penetration, not range. Battery capacity doesn't matter.
Of course, I'm in the US, so this more a curiosity than something I have to deal with. Sympathy, EU brothers...
Reactions: N30
Drone-Tweaks.com updated their app to 1.14.2 and FCC works,
contrary to my belief it does not allow you to tweak the altitude limit to 500m for the neo. There must be something new here, it works fine with mini 4k.
I took a look at the specs and I guess, this hack works similar to other early hacks. I think it's nothing else, just increasing the transmission of the 5G, since 2,4G transmission is almost the same for both ec and fcc models. The difference is the 5G. This is stronger in the usa. Unfortunately range and penetration depends on 2,4 signal strength. That's why I hacked my spark, but not the mini. But let's see....
Also interested to see what comes out of the (possible)... Mod. I would probably do it just for the sake of signal strength, not for the range (even on my other drones I never felt the need to fly kilometers away, just wanted more stable signal when flying close by). Let's see...
As I said in the "DJI Neo FCC patch" post, it looks like it took a little bit longer for the signal to get weak at the end, but not by much. Nice test anyway.
Hello, I am a new member (French).
I would like to switch to FCC mode to have better signal quality with the Neo and I would like to know if the HAM file hack works with the Goggles N3.
Has anyone here ever tried it?
(I don't have an SD card available for the Goggles and I'm bothered to buy one if the hack doesn't work).
Thank you in advance for your answers :)
New neopilot here.
Any update on this? Does the FCC mode work with just the RC-N3? Most posts and videos suggest that the update is yet to be made available.
WinonaDodg
