Neo Quick Transfer to iPhone not working.
Slade
Even with the proper cable my Neo won’t Quick transfer to my iPhone. It just sits on Idle.
I think the QT works via wi-fi / Bluetooth between drone and device.
A wire is used between the device and a computer to transfer content.
I don't have an iPhone but here is a video using the cable that may help.
Not sure if this will solve your problem but it's worth a shot.
I’ve tried this numerous times and run a battery down without transfer one 20 sec video. It simply isn’t working, even though it should.
  • Sad
Reactions: Erk1024
Interesting. Keep us posted
Reactions: sarahb and Slade
Edit
you have to choose "FILES" tab on the iphone, then it shows the Locations then internal storage, I was going into Photos, well thats logical i guess lol
I have a samsung phone which shows a drive but no files, i tried an Ipad 6 and this shows a drive in photos but no files, im not sure about the video above as I cant find anything called "Locations" in the menu
i reached out to DJI support and they told me that the Neo isnt OTG compatible and wont allow direct transfer to a device (unlike the DJI Osmo action 3)
The only way i can find is to use the Export function in the fly app which means having a phone tablet with you out in the field, if someone has a video with a step by step for ios and android i would be interested in seeing it
See Post #2
Reactions: NEO 317 and sarahb
Just tried transferring video from my Neo to my iPhone 12 Pro. NADA! Nothing.
  • Sad
I confirmed DJI FLY has Full Access. I’ve reached out to DJI.
Just heard back from DJI Tech. They recommended I turn OFF VPN and Cellular Data. That fixed it. All videos downloaded w/o a hitch.
Eureka! It was the VPN... cell data shouldn't be a player, as long as your wifi is enabled.
Give that a try next time – leave your cell connection on, just disable the VPN.
I use an ad blocker on my Android phone that works by passing all traffic through a local on-phone VPN that allows AdGuard to filter everything. I had to exclude DJI Fly from filtering to get the phone to connect to the neo at all.
Reactions: Adembar and Slade
Thank you for that input. I’ll try that next time.
Dogsbody
