Locking caps on Goggles 3
Does your lock caps on the bottom of the Goggles 3 unlock with the slightest touch. It's a bit annoying rechecking the lenses setting and was wondering if the use of a cap or accessory might help with this?
Very occasionally when I place it into the Avata2's sling bag which I use as a field bag for the Neo kit. Doesn't take and shouldn't require significant torque in locking and unlocking. Personally not a big issue.
It's not, I use a case but it doesn't take much to unlock I'll be a bit more careful about how I handle to goggles. I still a bit awkward about the handling of this new equipment. Once I get past how I approach my routine I'll be fine.
Don't do the Joshua Bardwell "drop". I try to remember to slide the battery pack below my occipital bone to reduce the chance of the goggles sliding off when moving them up on the forehead to see with my eyeballs. No idea what level of impact if any the goggles can handle. Guessing just a light bump or tap are the limits before something would break. $$$$$.
I'm very careful of how I adjust and lock for that very reason. I'm sure it would be very easy to damage to lock screw if care isn't taken. I'm getting more comfortable with the handling of the goggles during mount and dismount as it were.
stecobain
