I Don't undestandig nothing today
Adembar
Brazil
Website
www.youtube.com
I apologize to my friends for this comment being very long, but it is a description of an incident with me today. I went to film a place where there is the remains of a factory demolition. I had my smartphone in my pocket and placed the NEO already turned on on the landing pad, turned on the RC and connected the smartphone to the RC that was already turned on, accessed DJI Fly and then there was some confusion, because the NEO connected to the smartphone and ignored the RC, then I got a little confused until I managed to connect the NEO to the RC and then I waited a few minutes for it to connect to enough satellites for takeoff, but as there was a delay, I proceeded with the compass calibration, which occurred successfully. I tried to take off again, but it was still taking a while to be able to take off with enough satellites, but I managed to take off but with persistent loss of satellites, even at low altitude and without moving away from the RTH, I was afraid and landed, the screen recording is available on my YouTube channel, follow the link. I remember that the messages are in Portuguese because I am in Brazil.
Yeah I don't know, mine also seems to be slow to aquire sat. as well. I've went thru all the steps (I thought) to get my rc2 to reconnect to my neo without any luck as of yet. It connects fine when using my goggles n3 or 3 either one using the pairing method but not my rc2 I can see why you were nervous about flying with weak sat. It always connected in the past.
Good luck, I hope you find what what's causing the problem.
I contacted DJI support and they told me that I should proceed as follows:
Good morning!
Try to perform the firmware update as the step by step below on the control and drone:
ASSISTANT UPDATE:
1 - Download Assistant 2 for Consumer on your computer: DJI Assistant 2 (Consumer Drones Series) - Download Center - DJI
2 - After downloading the APP, enter and register your login details and DJI password.
3 - After logging in, connect the USB C cable to the computer, start the aircraft or control and when to beep you connect the cable to the drone or control quickly.
4 - The model of your equipment will appear, select.
5 - If there is any pending update, an official red button will be written next to the update.
(Note: for the upgrade to succeed the battery must be above 50% and the equipment cannot be disconnected during the upgrade.)
After performing the update, I kindly ask you to perform further tests and validate if your problem has been resolved if we do not ask you to contact again.
attentively,
Technical Support from DJI
And so I did, attached print. In my city it will rain for a few more days, I will only be able to do tests on the weekend, when I will then return to the same place for new tests.
I hope it goes as planned. In my case I finally got the rc2 to pick up my neo again and had 4 flights very fun flights today. Happy about that. Great flying weather.
Resolvido, após as verificações e reservas exclusivas da bússola, basta esperar alguns minutos até que ela conecte satélites suficientes para colar. Se cuidem, tenham um bom voo e que Deus os abençoe.Vídeo
