How to set gimbal mode to fpv
i own a neo
Hello, Does anyone know how to set gimbal mode to fpv on the neo? I checked under control in the settings and it’s not there when it’s connected but when I disconnect it the option shows up but is greyed out. I am using the RC-N3IMG_0014.jpegIMG_0013.jpeg
Confirmed.
With a one axis gimbal, it probably wouldn't float.
My old SPARK had a two axis gimbal and the FPV option was available.
The NEO 2 may have this option as well?
Confirmed.
As I remember the Spark and the 1st mini have this option. I flew both with dronemask (FPV 😁) turning this option on.
If everything's up to date and it disappears while connecting it means this aircraft doesn't support that function.
I've seen other people do it on the neo 1 with
the fpv rc 3 and goggles. I think it only gives the option on the goggles.
It's not an option, you've got no choice. With the 1 when you're flying with the goggles it's always "FPV" and when you're flying with the app it's always "level horizon".
With the Neo 2 you can choose FPV mode with the app but then when flying with goggles you can't have it without being in manual mode... always different available options in each different mode on each different aircraft
Aniket Dengre
