Dumb ways to lose your Neo
h3045
Dedicating this thread to ways I found to potentially lose/damage my neo (but so far luckily hasn't happned)
Hope others can share some of their interesting observations too. (If some information seems at odds with you, please correct)
1. Flying with mobile out of wifi coverage
- Drone will hang until battery drains
2. Flying in dimming light
- Starts something called attitude mode and the drone just behaves like a drunken sailor
3. [RC-N3 + drone] - Flying beyond radio signal
- The drone begins it's RTH (Return to Home) but the first thing it does is goes to the RTH altitude that you set. This means that if there is any vertical obstruction, the drone is doomed. (Mine got stuck on a tree)
- After attaining RTH height, it goes through a directed path, but does NOT do obstacle detection. (Mine was about to hit a building)
4. [Goggles 3 + MC3 + drone] - Enter settings for MC3 mid flight
- This was the dumbest/freakiest way to lose my drone and I hope a software patch fixes this. If you are mid-flight, and for some goddamn reason decide to go to the MC3 tutorial in settings ( I did it because I forgot one command and wanted to quickly take a look), the goggles stay on the tutorial screen but the tutorial will not start because you are mid-flight.
It's crazy! I could not see through the goggles, and my drone was somewhere behind a big building. I did a RTH and luckily there were no vertical or horizontal obstructions so the little guy returned. Then I could "start" the tutorial for MC3 on the goggles and my view reappeared! So stupid but scary.
5. Flying in gusty wind
- I've been pushing the drone against strong winds and at one point it sort of flipped but realigned itself. I think it could have just as easily flipped out and would have "gone with the wind"
Bonus: An eagle snaps your drone
- They think it's easy prey and attack it. Just a poetic way to say goodbye.
What are your freaky neo stories?
Awesome thread! What a picture!!
I always worry about the emergency motor shut off positioning of the sticks while flying.
Not me, but I know of two pilots who were neglectful of having a full charge on their device and one had a flyaway, the other a RTH.
Reactions: h3045
I need to test that with the NEO.
Years ago with the SPARK, it didn't work. It would spiral down but wouldn't shut the motors off.
I never tried it with the MA2 but the NEO is so light, it shouldn't damage it unless it falls on the gimbal.
When I seen it in the listing as I remember it says in case of emergency only but I didn't see an option to turn off altogether.
When I checked AI just now this is what it said.
No, the emergency stop feature on DJI drones cannot be completely disabled. While you can't turn it off entirely, you can configure it to only activate during an actual emergency. This feature is a safety mechanism and is essential in situations like auto-RTH (Return To Home) failures or if the drone is causing a threat.
Does the PIC decide what the emergency is or does the drone?
I appreciate the input on this maybe I've misunderstood.
Yup that's how it is, i.e the drone will only accept your stop command if it considers it's in an emergency situation. We don't know what that exactly means, but probably stuff like hit an obstacle, lost a prop/motor/ESC, is upside down etc.
Thank you, that was something that was always bothered me about this feature. I'll be a little more relaxed about it now, especially starting out with this FPV flying that I'm not used to anyway.
I never thought of it this way, but maybe when you're flying and transition into that position in the corners it's not a problem. But if you start from the center position on both sticks then move both to 45 deg angle straight to the corners that's the failsafe that trips it finally but not accidentally while flying.
The worst thing I've done is fly it over a lake with 1 connection bar while the battery is at 15% (not a great idea). almost lost it
  • Wow
Reactions: h3045 and RcHawks
This happened to me too. The drone starts emergency descend at the worst time.
Reactions: i own a neo
Watch Ken Heron´s youtube chanel...
I felt quite guilty laughing at some of the fails because it could eventually happen to me too. But that's for the share, it's hilarious
He´s got a 4 hours long crashes only vid, that beats everything
His other videos are cool, but this feels a little overproduced making it harder to watch. But the message is loud and clear; trees and drones don't go.
IMO all his videos are overproduced, but he´s got the largest collection of crashes. When I was noob, kept on watching drone crashes and tried to learn from other´s mistakes. Working...
AddieBurne
