Well, that didn't go as planned aka, Alexa stinks.
tstr14
Active Member
The weather here has cooled down, and I decided to go flying. It had been awhile since I flown the Neo, so I plugged in the charger and as is my customary procedure, I asked Alexa for the current windspeed. "She" replied 5mph. Not ideal for the Neo, but OK. When the batteries were all charged, I drove to a local park. With lots of trees around, I noticed their movement, but it wasn't bad. Up went the Neo and as soon as it cleared the trees, I got the warning WINDY CONDITIONS, Return to Home may not work, or words to that effect. 5 mph indeed! Well alright then, I'll just come back down.....
Ha ha, said Mother Nature, you'll do nothing of the sort! My attempts to land were thwarted by the wind trying to blow poor little Neo into the trees. In addition, it couldn't keep up with the wind, and was steadily being sent eastward, away from me and the park and into a neighboring residential area. Oh, and I kept losing the signal, during which time the drone was simply driven further and faster away by the wind. Even my attempts to land ANYWHERE were canceled out by the on again / off signal loss. My last communication said the Neo was 70 some feet off the ground and doing a forced landing because of loss of power (obviously the struggle went on for some time). The screen indicated it was a bit over 2200 feet away, well outside the park. I was quite a ways inside the park, which meant if I wanted to drive, I would have go all the way to the park exit, then double back outside the park to find the drone. Fortuitously, next to the parking area was a open gate on a path that led outside the park. So with "Find My Drone" activated, I began hoofing it.
A little over half way there, I was passed by a jogger. Seeing the RC 2 in my hand, he made an educated guess: "Flying a drone?" "Not any more!" I replied. He laughed and wished me luck. "FMD" was amazing. At the exact location indicated on the screen, I found little Neo sitting on the grass, no worse for the wear.
So went the saga of my first lost drone. Props to DJI for the Find My Drone program! I worked wonderfully. Alexa on the other hand can go pound sand...
I’ve never had to use that feature, but it’s good to know it works so well. Good to have in the emergency bag of tricks. Awesome that you got in back in good condition! Very good description of the event.
Reactions: tstr14
Depending on how much you're flying, and what types of other drones you might have, the UAV Forecast app has been well worth the purchase price. There is a freemium version too that has limited functionality.
For weather I only trust UAV Forecast and the Weather Underground site, Local Weather Forecast, News and Conditions | Weather Underground. Alexa, AccuWeather, Apple Weather never really have the weather specifics we need.
That's why I stopped using it.
It use to have a three day free window that was convenient to use but the app changed and I'm too cheap to purchase the app. :rolleyes:
Reactions: davedoc and RcHawks
Don't use apps for flying. Not clever. Personally, been flying for 51 years and if I depended on something akin to an app, I would be dead now, well actually a long time ago. Even our METAR is dubious in the flying world. You have no idea how many times we, half jest whole truth, would ask the briefer on the radio to look outside please. I have also been in a situation on the ground were it went from under 5 knots to 85 in less than 10 minutes. Apps also are lousy for very localized conditions.
Get one of these: they used to available on AliExpress for under $10, where I got mine
Reactions: davedoc
I got one of those, different style and brand.
I have thought about one of those. How well does it work? A big part of my problem was that I took off from a protected area. As soon as the drone got above the tree line, things went south rather quickly.
It works quite well, you do need to get it oriented correctly into the wind. You need to measure before you get to a protected glade. Typically if you are in a valley or a bowl, you can expect the wind to be higher above the tree line. Wind is almost always lower near the ground due to friction with the ground and things like trees. So you need to expect that, but you can measure it if pass down through a clear space. Really the Neo can not tolerate much wind at all. I had mine while hiking in South Africa this spring. I was at the top of a mesa and thought it would be a nice shot looking over the edge. It was not much of a breeze, but the poor Neo was screaming, bobbling and healed over nearly 45° to stay in place. My other drones can tolerate quite a bit of wind, so I too am easily fooled by what it can tolerate.View recent photos.jpg
Reactions: tstr14 and RcHawks
