Pushing through the 120m altitude
h3045
Hi,
New pilot here. Loving the neo.
I want to take this drone higher than 120m.
Does something like drone-hacks help?
I think I have FCC enabled through a some patching solution (not sure if it works)
Reactions: sarahb and GFields
Multiple days flying below 30 meters in calm to light breeze (F0-2). Push it too high and high wind warning kicks in. Neo is relatively underpowered in N and S mode. You really need to fly in M mode and have the skill to deal with the wind if flying in F4 or greater. The max IIRC 8m/sec in S mode is too low. Something to consider in your quest for higher altitude.
Home is located half way up a ridge overlooking L. Superior. If I fly towards the Lake at 30 meters relative to launch pad my altitude over ground is reaching the 400ft ceiling. Bummer is heading uphill. +100 meters to the top plus some 30 meter tall trees.
Not sure if aware regarding the Neo. In high winds when flying M mode it "kites" with a strong tail wind. You sort of have to reduce the pitch and modulate the throttle to maintain a level flight. Opposite heading into a strong head wind. Increasing the throttle and speed over ground (SOG) push Neo downwards. If hitting a specific combination of altitude and distance the Neo auto switches from M mode to N until you reduce altitude. Real pita if you need to fly back down in a strong cross or tail wind. I can imagine hearing the ESCs and motors screaming to maintain the built in stability parameters.
As you probably know, in the United States the max legal altitude is 400 feet. 120 meters is just under 394 feet. I assume that is why DJI limits it. I do wish companies would not pretend to be my nanny. I don't mind if they warn me I am about to break the law but, don't stop me if I want to. I was very happy when they removed the geofence. Now remove altitude limit to. Set the default limit to 120 meters but, let me set it to unlimited if I want.
Greetings from Birmingham Alabama USA, welcome to the forum! We look forward to hearing from you!
Has it got a hard 120m limit? Really? I guess I hadn't tried to fly it higher.
That's a bummer, since the law doesn't limit you to 400' above launch point, it limits you to 400' above the *ground* which isn't the same thing if your ground isn't level! (Not to mention the exception if you have a part 107 and are flying it within 400' of a structure, where you can fly it up to 400' higher than the structure)
I dont think a sub 249g selfie drone like the NEO is up to the task of a Part 107 certificate flight 400 feet above a 400 foot structure.
h3045
