Propellers for Neo
I like gemfans. I use 75s on my Tello with very good results.
I consider buying a pack of 5 blade neon green and blue 4 blade for the neo.
Just placed the order. The 2 packs with s&h was 12€.
neo green look absolutely great!
I am waiting my 4 blade to be arriving soon.
Just want to pipe in and say the members here are awesome sharing the ideas amongst other drone pilots.
I don't have a NEO or an FPV drone but it's cool to see the chatter about the environment of research and development.
Three blades. Maybe four or five. ??
Sounds like a tagline for a razor blade manufacture. :D
After all, we are cutting the air the best we can.
Keep up the good work. 👍
Those should raise the pitch about an octave. A bit less because the motors don't have to spin as fast, but it will be considerably more mosquito-like, but probably a little quieter.
I don't know about the pitch, but one site said they lowered the noise. At $3.88 a set, I ordered them to give them a try. If they don't work, I'll make a salad shooter out of them.... 🫣 😁
Sound check
Reactions: Adembar and NEO 317
Christian, what screws did you use with the GenFan d 51 props?
Yeah, that other 5% of the time 😉
The additional almost 5gm of the top guards supposedly reduce the bench flight times that DJI notes from 18 down to 17 minutes. Real world without the top guards on I've been getting 7-10 minutes gentle flying in Manual mode and 10-11 minutes in S mode using the FPV RC3.
Haven't tried flying with the guards. Every gram counts in these micro quads. Only immersive flying. Not into the autonomous features. They came off before the first flight. But maybe yesterday I should have had them on. Broke both the propellers on the starboard side after bouncing off an obstacle and not being able to recover. Neo ended up resting upside down under the running boards of my truck on my crushed blue rock gravel driveway.
At least the Neo stock propellers are not too DJI stupid expensive. Unlike the Avata2 propellers. Use to the HQ and GemFan that sell for significantly less.
Avata 2 (1): GemFan 3032x3 - Neo (1): GemFan D51x4
Avata 2 (2): HQ 3x3.2x3 - Neo (2): HQ 2x1.6x3 GR
Other not in use Props: GemFan D51x5, HQ T51x6, HQ 2x2x3, Original...IMG_20250702_165403.jpg
Loonatix FPV
