New firmware DJI Fly 1.16
I originally had 15.8 on the iPhone. Activated Neo#2 yesterday. Linked it to the Goggles3. No problem. At least with Neo#2.. Posted issue in another thread. So, not being the brightest bulb in the room. Then checked to see if DJI Fly App was up to date. Nope. Updated the app. Still issue as noted in other thread. Which makes sort of sense. 1.16 just updated to support guess what???? The FLIP and the usual "known issues" that DJI never defines.
Every update to any software usually has bug fixes in it. These are “known issues” to the developer, and usually too esoteric to be reported on the fix list that you might read. It is the nature of software development that there are constant patches, especially when new features are added.
"Fix known issues" is also the "excuse" when you don't want to bother listing important stuff or worse don't want people to know about something, and DJI had a heavy track record of using it that way...
Yes, here you go, here's an example: "Fixed command FIFO buffer overrun in positioning module resulting in random missed command packet found during regression tests. No known impact on flight behavior or performance."
20 things like that could be listed. I'm fine with "known issues fixed" 😁
Reactions: NeoNeo and Adembar
"known issues fixed" for this Luddite might as well be ancient Greek. Actually any language alive or dead with the mostly the exception of American English. Which according to a British friend is not "proper" English.
DJI explained in their forum once that "known issues" are related to software code changes that the majority of users won't notice.
I sure don't notice the "known issues". Was flying the Avata2 with only the 1st firmware update until I purchased the Neo. Flew fine.
Firmware updating was the most "painful" aspect of setting up the Neo. Updates for everything in addition to the Neo updates. Bit tedious when your max download speed is 7mbs.
Thanks for sharing.
KeithRicci
