Goggles n3 quick question
Poverty Flyer
Seattle Wa USA
When I start the goggles n3 and the motion 3 a message pops up that the goggles tutorial has stopped unexpectedly.
How do I stop it from even starting?
Beginner mode is off when this happens.
Other than that, fantastic piece of equipment.
Thanks
Maybe manually start the tutorial and watch it through to the end? Maybe it thinks you haven't watched it clear through, or something. I've not seen that occur with my Goggles N3 at all.
I have never watched the tutorial.
I also can not tell it's running until I get that message.
Thanks, I'll give that a try.
I was also thinking maybe start in beginner mode watch or back out and say don't show again.
Just got it yesterday and I am enjoying it.
Cheers
I love flying the Neo in FPV, it is as close to flying as I will ever get.
Yeah, me too.😁
I started to get my pilots license about 45 years ago but took a transfer at work and moved out of the area.
Then life got in the way as did work, kids, etc.
Next time for sure.😝
Reactions: JustDavid
The issue went away after going to beginner mode and watching the tutorial backing out and checking the do not show box.
Everything good in normal mode now.
Lovin this little guy more with every flight.
Thanks for the help.
I have definitely seen it. Launching the tutorial is confusing because it tells you depress the 5D button. The 5D button is the toggle button on the goggles. But it shows the hand controller, so people think the 5D button is on the hand controller. And you cannot launch the tutorial that way. So people simply bypass it. Including myself. Without the tutorial, I had no idea how to land my drone on the first flight, a couple days ago. I just had to wait till the battery ran down and it landed itself. 🤣
Reactions: Poverty Flyer
They fixed the problem on the Goggles 3 tutorial. It actually shows the goggles instead of misleading you by showing the motion controller when telling you to press the 5D button.
HMS Warspite
