ND Filters: NEO 2 Clip vs Adhesive Magnetic Ring
NEO_GMAN
I plan to purchase a set of NEEWER ND Filters (Clip On) for my NEO 2. Any member feedback / comments? Secure? Issues ? I have a similar design/ set for my NEO (K/F Concepts)…works fine !
Reactions: JustDavid
I have the sunnylife clip on filters and they work good. Just don't buy the magnetic ones as they fall of in minor crashes.
Reactions: NEO_GMAN
Same here. I have the magnetic ND filters for my Neo 1. Crashed and lost it. I'm done with magnetic. I'll be interested in the clip on ones for my Neo 2
Reactions: NEO_GMAN
I will repost and update once I have a chance to evaluate the Clip Version from NEEWER. The version I use for my Neo (K&F Concept) works fine …
I ordered the same, just waiting for delivery.
On my OG Neo, I used similar clip on style ND filters and and am very pleased with them.
Clip on ND filters
Reactions: NEO_GMAN
I finally received my purchase order of the NEEWER ND Filters for the NEO 2. As mentioned earlier, I was a little skeptical about “other” magnetic / adhesive versions.
I have a few remarks to share: (1) The added weight of the ND Filter requires you to power up (at rest) the NEO 2 on a stable / level surface to allow the gimbal to complete its initialization process. (2) Affixing the ND Filter (Clip) takes some practice. Unlike the NEO, there is no “snap or click” to know if the ND Filter is firmly secure in place.
Mechanically speaking, the “clip” design to hold the ND Filter in place depends on the “stiff flex / tension” from the two prongs. Examining and confirming (checking) the placements of these prongs are paramount.
It would have been nice if NEEWER added a lower (bottom) clip to “clamp / pinch” the Filter Optics (frame) in place against the Gimbal assembly for added security…
Enough said — I will report an update after a few sorties ! 👍🏽
Great info, I just got mine from the mailbox 5 min. ago. Thanks for report
Reactions: NEO_GMAN
Managed to warm up enough for me to get an outside flight. The clip on ND filters work well, and feel very securely attached.
Pic is at 390 feet, looking north at my small hometown.
Nice pic, and thanks for the update. Still a little chilly here for me to fly. Looks like a couple of days before I fly.
Stay warm
Thank you for the feedback. Yes -- it is so COLD outside (single digit) in NYC (LOL)... I did a few "indoor" sorties in an empty basketball gym. Darn "Clip" didn't fall off :-). So far so good ! Happy / Safe Flying !
Temp is only 7° this morning, but THANKFULLY, temps should hit 40's next week! Might try some FPV flying around our yard if it hits 40° or higher.
I will be so happy when all this white stuff is GONE!
Reactions: NEO_GMAN
Me too. I'll be flying my new Avata 2 for the first time looks like Tues. for me!!!
In that pic, what drone was that? and did you have any problem with the downward facing sensors over the all white ground?
Neo 2. And no, I didn't have any issues. Launched from my hand out the back door then stood inside and flew with the RC-2
The jury is still out...
It's been very cold and windy outside, so I decided to run a few test flights in a control environment (basketball gym). It's been a trial and error / learning curve when it comes to using these NEEWER ND Filters: (1) Properly Attaching the ND Filter to the Gimbal Unit and (2) Initializing (Power Up) the NEO 2 on a level surface to allow the Gimbal to auto-center (reset).
So here are my current "rookie" mistakes / observations:
In the attached photo, I think (at the time) I attached the clips (prongs) as shown (marked) on the RED Line. The video results were shaky (jello), jerky and blurry. I was not sure if the Gimbal was out of whack or vibration from the motors cause the distorted video image.
I did a re-calibration check and experienced the same results. But once I removed the ND Filter -- everything went back to normal...WTH! I started to think about a "root cause".
I placed the ND Filter back on...but positioned the "prongs" on the GREEN Line (further back of the Gimbal).
Ironically - no more shakes, jello, or out of focus behavior. I will continue testing with the ND Filters. But for now (compared to other DJI / ND Filter attachments) -- this is very finicky given the way NEEWER designed the clip and ability to hold / firmly secure a good interface against the lens. It would have been nice (design) if NEEWER added a clip / prong on the bottom part of the filter housing to offer an even "clamp" against the Gimbal.
The saga continues ... 👊
Boy, If those nd filters are that much trouble ,I think I'll go without and send them back. Let's wait and see what other Neo 2 owners are saying about those filters. Anyone else using these filters? Please let us know your experiences.
Reactions: NEO_GMAN
Honestly - I think it's end-user / operator error (me) when it comes to the correct / exact placement of the clip / prongs. In my photograph -- I initially positioned the clip / prongs on the RED Line. I later repositioned the clip / prongs further back (GREEN Line). I ran a few tests and the video looks normal :-). I am still testing. I plan to run a mini design of experiment (DOM) with the clip / prongs re-posited to the RED Line to re-create the video flaw (shakes / wobbles). Stay tuned :-). On a side note, the instruction sheet from NEEWER is very vague in some respects. If you troll around YouTube or Google AI -- it is still unclear whether you turn on the NEO 2 with the ND FILTER already installed or attach the ND FILTER after the initial Power ON mode. For me -- I keep the ND Filter on...and Power ON the NEO 2 on a flat level / stable surface before picking it up... Taking the ND Filter ON and OFF would be a major P in the A !
I would never try to attach anything to the gimble while it was powered on. Why risk damaging the tiny motors in the gimble.
While I'm not encouraging people to manhandle and abuse the gimbal, the motors themselves are not so delicate that any damage will occur from turning against the EMF they are producing. They are BLDC motors and not very strong at that, so all forcing away from where they want to be will do is produce an overload error, which is harmless.
Better not to, so put accessories like filters on with the drone off. However, the small forces applied that deviate from where it's trying to point are completely non-destructive.
A quote from NEEWER Customer Service.
“…Due to the Neo 2's unique structure, the gimbal locks the maximum angle, so we recommend using it after powering it on, or taking off horizontally; otherwise, the gimbal won't automatically detect and allow it to pass...”
I am not exactly sure what they (NEEWER) meant, but I would never attach a ND Filter on a live Gimbal (servo motors). Just my opinion….
