Hearing Protection
Just as a side note I would like to suggest for others to wear earplugs when turning devices on and off as the beeping is very loud and over time could harm you hearing (my opinion). I wish I could dial that down some but that doesn't seem to be an option to reduce the volume. The Neo itself can be loud but my issue is more directed to the startup and turning off of devices since that is where you are likely to be the closest to your ears.
Shouldn't be a concern. Sound pressure IIRC when testing the MasterAirScrew Avata2 propellers of the beeps of the Goggles3, FPV RC3, and Avata2 beeps didn't exceed 65dB. For most people ~30dB is the threshold for hearing. Quiet whisper is ~40dB. Normal speaking volume.
But if really feeling the need. Recommend Loop Engage. Cuts ~16dB or add the mute plugs and reduce the noise level by 21dB. Still allows you to hear detailed sounds. Tried some of the knockoffs. Significantly less $s, but they muffle detailed sounds. Foam cheapo plugs are better less than the knock-offs and do a better job for noise reduction.
Just thought I'd throw that out there for someone to consider as an option is all.
Any particular brands or models in mind? I’ve honestly never used ear protection in my life, so I’m starting from scratch here. Lately, I’ve realized how important it is to take care of my hearing, and now I look to order hearing aids online. I’d love to hear what’s worked well for others — things like comfort, sound quality, battery life, and ease of use are all big factors for me. Any recommendations would be super helpful before I make a decision.
Definitely not recommended!
Ear plugs destroy your situational awareness, which is a definite requirement during launching and landing. You need to be acutely aware of all sounds around you, which is why it is illegal to drive or bicycle with headphones on. Ever tried to get someone’s attention while they are wearing earbuds, to warn them of an impending potential danger they are unaware of?
Reactions: Christian
The orange ones have a db rating of 33 while the greens ones are 27 I believe.
