Get the alternative battery charge hub
taitony
Just get a alternative battery charging hub from China. It has three difference with original hub:
1. It has "storage mode" if you do not use Neo for a while, it will set the charging limit to 60%. When you plug the charging cable into hub and press 2 seconds and tuen on "storage mode".
2. If you do as Power bank to mobile phone, the output is 18W instead of 10W as. original
3. It is very thin for easy packing for hiking.
I have sold my original DJI Hub.
Right now both the Avata2 and Neo charging hubs are basically "dumb" chargers. Even my 2s tiny whoop charger has the option for storage level charging. Sure hope this aftermarket charger is functional and uses DJI's charging profile vs. ???? Right now after letting the batteries "settle" I need to monitor the charging and manually pull the battery out when I think it is close to storage level. Or when lazy just charge to full and potentially waste part of a battery life cycle.
Reactions: taitony
RoscoeHers
