Aim was bad
If the aim was bad on the first attempt, then we go back and try again.
Looks like you put it through using your hands instead of flying it lol
Clarifying: when I'm entering the location, the NEO is in flight, but when I remove it from the place where it crashed, I do it with my hand up to the landingpad and then NEO flies again.
There might be some rebar in the structure that may momentarily affect the compass when passing through. 🤔
Yes, good point, I hadn't thought of it that way.
Fly faster, so it won’t have time to react to any rebar! LOL!
It's a double edged sword, because faster flight means more potential damage if you miss "the gap!" Make sure to turn on crosshairs and a center spot over your display for best results.
Yes, good idea, thanks.🤗🙏🏻
Reactions: GadgetGuy
Funny thing about drones in general and holes, big and small. They just do not like them. I have a floatplane and had a much larger turbine powered one as well. I was in the process of selling the large floatplane and thought a drone shot of it on the lake would be cool. Really, you need a spot to landing takeoff with the drone (It was a Mavic 2 Pro), out in the middle of the lake. The airplane had a large 1.5m x 2m cargo door opening. Big deal, launch from eh cargo area. Well in testing, I could get it to go out the cargo area, but I could not coax it to go back in. Airplanes are very non-magnetic.
Ended up having my bud coming out in his Husky and do the shots.
Reactions: NEO 317 and Adembar
kurochel
